1 - 20 of 35 Posts
Hi
I just moved into a new house and my HT room is way bigger now then my previous. I have the SVS PB10. After weeks of work in the new hous I finally got some time to calibrate my sub yesterday. Unfortionatly I got a very weird measure result.
As you can see the graph peaks at 20Hz and at 25Hz it just drops down and comes back up only about 50Hz. I tried moving it around a bit in the front from left to right but it doesn't change much. for now the sub was only positioned in the front corner of the room. Maybe I have to try to position it behind or a couple of meters aside the listening position. The problem might be that my room is not only much bigger (8m x 5m), but as you the ceiling also goes downwards at the sides like a roof of house (see pic 3, it's a view from the side) and there are 4 windows so there is kinde of a niche on each window (see pic 3). Maybe the frequenties above 25Hz get lost in the window niche right next to the sub?
Do you have any tips where I can try to position my sub?
And is it a good idea to boost the gap of frequenties or will it stress the PB10 too much?
sorry for my poor english but it's not easy to explain. :scratchhead:
Re: gap in my graph
You're using a rather exaggerated vertical scale in your graph that make the situation look worse than it is.
Post your graphs in the standard we normally use here at HTS.
Vertical scale = 45dB-105dB.
Horizontal scale = 15Hz-200Hz.
Be sure to show the target at the crossover frequency you are using.
Super Moderator
Re: gap in my graph
In the meantime:
You really can't stress that subwoofer because it has a built-in limiter. Boosting will reduce the amount of headroom you have, which means you won't be able to get as much SPL as you would otherwise. But let's wait and see what your new graphs looks like...
Re: gap in my graph
Ok, did another measure today.
I found a picture of my room before we moved into the house. In the right corner where the sofa is located, behind the soccergame table, that's where my sub is now located. Just to give you an idea how my room is shaped. So I did a new measure of the same graph from last week and did the settings as you asked, but not much changed.
then I moved the sub to the window corner right next to the hall (see top shot scetch of my room at the top of this page). Out of this measurement came this graph. The gap is much less But I lose out a few frequenties at the bottom end.
So look like I have to choose. keep the sub's current location and have the 20Hz but with a gap after 25z, or have balanced line but lose the bottom end frequenties. Maybe I've come to the limits of the pb10 and my room is too big for this decent but entrie model. Either way, I was hoping to upgrade to the pc13 if my poor student budget allows it somewhere in April or so.
Re: gap in my graph
that original with your dip doesn't look that bad. If you have an eq, you could cap some of those peaks and smooth things out a little bit. But that sub looks like it is handling the room fine.
I would read up on adding a house curve next.
Re: gap in my graph
Where would you change the peaks?
I've heard of a house curve before, but don't have a clue of what it is or how to do it. :p
Re: gap in my graph
Simply lower them with a BFD. REW will recommend the filters to use..
I already tried, but it always says: "there are no peaks to be equalised" or something like that. I must admit that I haven't worked with REW for over a year so I probebly overlooked some steps. unfortionatly I also have very few time left these days as school projects are requiring more and more time as the hollidays near.
Super Moderator
Re: gap in my graph
That's because REW looks for peaks in relation to the Target Curve. Your first graph had the signal so low that it was all below the Target:
Your new graph has the levels up where they should be, and as you can see the peaks are now above the Target Curve. REW will recommend filters this time.
Discussion Starter · #17 ·
Re: gap in my graph
Ok thanks, I set the filters. I only should do another measure to see if the result of the filters are really as good as REW predicts.
I don't want to seem lazy. But can you tell me in short what a house curve does and how I can do it? I really have very little time on my hands these days and I don't want to get it all to technical.
Re: gap in my graph
The short, very simplified version of "Why do I need a house curve?" is:
The human ear is less sensitive to lower frequencies, so you need to reproduce them louder to make them seem as loud as the higher frequencies.
The even shorter version is:
It will sound better.
As for how, and a more detailed explanation, read the links that Buk gave in post #11 above.
Re: gap in my graph
Can you please explain how changing the vertical scale changes the data in the measurement?
Subby, what mic are you using for your measurement? Also, can you post some waterfall plots? Behavior like you're seeing is very typical of room modes - the most reliable band-aid will be moving your listening position and subwoofer.
Re: gap in my graph
I would argue that the non-linearity of human hearing is compensated for during the recording process...even in the most simplistic of recording techniques, you're still choosing the mic location with your ears.
I'm not saying that flat response after room gain is the ideal, but I do find that a "house curve" following the Fletcher Munson curves is going to be way way overexagerated. I think the ideal lies somewhere with the effects of the group delay from room gain...
1 - 20 of 35 Posts
