1 - 5 of 5 Posts
First of I just wanted to show off some pictures. These may not be to the specific size requirements, but it's not really what the post is about.
I made a jig for measuring polars and did some graphs with REW of this build. Either 1/3 or 1/6 octave smoothing for a clearer picture. I can't remember what I used now. Notice the difference between L and R. It just shows how much baffle width has to do with dispersion as these OB speakers are an off center mirrored design.
On axis left speaker:
On axis right speaker:
11.25 degrees off axis left speaker:
11.25 degrees off axis right speaker:
22.50 degrees off axis, left speaker:
22.50 degrees off axis, right speaker:
33.75 degrees off axis, left speaker:
33.75 degrees off axis, right channel:
45 degrees off axis, left speaker:
45 degrees off axis, right speaker:
In any case, These are not gated except for the default gating in REW. I really need to make gated measurements. Does anyone know if the gating in REW is real or simulated? Can it be set to a tighter gate to default to?
Thanks a million!
Dan
It's real since the result of a measurement in REW is the impulse response. All other graphs are derived from it. REW has a default gate that's applied to your measurements. Take any measurement you've taken or saved and alter the gate as required.
See this post for a basic explanation.
Thanks Brucek! I was looking for the specific information you just gave me for like an hour yesterday, but just couldn't find it. I knew someone would be in the know.
I appreciate the help,
Dan
How about some pix of the apparatus?
1 - 5 of 5 Posts
