1 - 5 of 5 Posts
Hello Folks, anybody never used the Generator -> Square Wave option?
I am using ver 5 last beta 9.
All the other Generator options look working as expected, so I believe it to be a sw bug.
Looking forward for the fixing.
Andrea
Well it works on my computer running Win XP Pro SP3 .
Confirmed that it was indeed a Sq Wave by looking at it on a software based oscilloscope ( TrueTRA ) .
:sn:
Wow! Very strange!
I tested each one and all works fine except the Square Wave that doesn't do anything.
Actually, it doesn't work in my case.
I am using Windows 7 32bit and I set REW at 88.2 kHz sampling. The ADAC (sound card) is a MOTU 896 mk3 driven by ASIO.
Thanks and regards,
Andrea
There is a problem with the square wave generator at sample rates above 48kHz, I've fixed it for the next release. Thanks for spotting that.
Discussion Starter #5
Hello John, I confirm your post, at 44.1kHz I can get a perfect Square Wave.
By the way, I have also problem calibrating the card at 96kHz and it looks to be a synch issue.
I am now going to make a new thread about providing graphs also.
See you later!
Kind regards, Andrea
1 - 5 of 5 Posts
