I am not sure I am doing anything wrong which is even more puzzling. At first I could not get the UMIK file to load into REW. I reread the step by step guide and went back to the preferences section on REW and finally got it loaded, I know its there as you proceed along I set the generator to to play pink noise adjusted the SPL hit the calibrate butten a window popped up and said no need to calibrate the mic file is recognized or something to that affect. I did a measurement it went smooth pretty simple and after when I got the graph it got blah. I went to EQ.checked the mini for my eq. then went to target settings made sure that was okay then to filter tasks then hit set target level and after match response to target. No issues saw the filters I needed then I read you could auto. send the filter settings to the mini yeah right!! I tried numerous times nothing. I ended up doing it manually so that is where I am at I had a pretty good headache going yesterday. I also had made some dumb mistakes along the way one of them when I first got the mini I connected my sub amp to input 2 on the mini without reading I assumed output 1 and 2 would be used that is wrong with Input 1 use output 1 and 3 Input 2 use 2 and 4 I fixed that but this was after I gave up and put things away I have no idea if this will make a difference yet going by MURPHY's LAW probably not.
Any ideas please??
