What is the best way you have found to get IR emitters to stick into place? I have tried both Xantech and now Smarthome brands - the adhesive pads on the Smarthome ones hold a little better than the double sticky tape on the Xantechs. But either one will come off easily.
The biggest problem is getting them to stick on the DirecTV HR20 series DVRs. The IR window is slightly curved so there is not full contact with the adhesive.
I have resorted to black electrical tape and also white foam adhesive tape across the wires to the emitters, but that looks bad.
Other than Crazy Glue, what has worked for you? Thanks.
