1 - 3 of 3 Posts
When using the gizmo without a sub are you just supposed to boost the bass level in order to defeat the 100hz crossover? :no clue:
If there is no subwoofer in your setup, the bass have been designed to give a boost that matches the roll off down to about 48 Hz . At max setting, it will give about a 2-3 dB bump at 48 Hz, relative to 100 Hz. So, with or without a subwoofer, the Gizmo will provide real-world performance.
edit: I ended up setting the bass boost to one position below max by ear, but still would be curious how it works.
1 - 3 of 3 Posts
