1 - 3 of 3 Posts
G
Does anyone think the screen goo is worth the money? I have heard that flat wall paint is nearly just as good.:dontknow:
Moderator Emeritus
Hi dwmusser,
I don't have any personal experience with Goo products, but I believe you can achieve your DIY screen needs with less expensive alternatives.
Please tell us what projector you have and some data on your viewing environment; such as room size, the color of your walls, floor and ceiling, how far the screen will be from the projector, physical screen size and how much light from windows or other lighting will be in the room (called ambient light) when viewing. We can then give you better recommendations.
1 - 3 of 3 Posts
