You can't. You should have rec-in and rec-out rca connections on your receiver to connect the eq. Newer receivers are not coming with those connections anymore. You should use the receiver onboard eq or you can use an external amp to connect the eq between your receiver and the amp.
To acomplish that your receiver should have pre out connections otherwise is not gonna work.
