1 - 3 of 3 Posts
Hello everyone,
Just started to use REW and have ran in to some problems. I´m experiencing some problem with graphics in REW see picture below:
https://s14.postimg.org/kwtgxk29t/REW_problem.png
As you can se I cant work with anything in the EQ window because I can´t see what I´m doing.
What could be the cause of this? I use a new computer with windows 10 on it. Atm moment I´m running latest beta version of REW. But I tried last stable release as well.
BR
Jontres
The cause is a disagreement between Java and the graphics card driver. If updating the driver doesn't fix it you can disable Java's use of hardware acceleration as explained here.
1 - 3 of 3 Posts
