1 - 10 of 10 Posts
I have this Sony DLP television and the screen has gone green. I've read a few postings and cannot find a good answer.
Is it the projection bulb? Is it the connections (I've tried every input and get the same problem)?
Plain ole user
Your set is not DLP. Sony never made any RPTVs with DLP. Yours is what they call SXRD, which is the Xony flavor of LCoS. Post an image and more detail about the green and perhaps we can tell if it is a common problem with the optical block or something earlier in the circuitry.
Thank you - you're right, it is an SXRD -
Are you asking for a photo of the TV screen to show the green? I attached a shot from my cell phone (my camera was dead - and no AA batteries in the house - go figure). The picture is blurred, but the color is pretty accurate.
It started as a discoloration that I couldn't fix through the color settings.
The picture has become progressively more "green" yet every once in a while a commercial comes on with what appears to be perfect color...
Thanks,
Malcolm
Plain ole user
Is it uniform over the screen? If you get some images that have correct color, what kinds of images are those?
The green started on the right side of the screen and over time has moved across the screen to what the picture (above) now shows.
On the few occasions it shows good color, it hasn't seemed to be of anything particular image that stands out to me - except now that you ask the question, it only occurs while the screen is all graphics (no people in it). But that doesn't mean that it is that way everytime graphic-only scenes come on, only that when it does happen, it's on a commercial (another clue, perhaps) that is showing graphics only.
Thank you for your questions - I hope we can figure this out and I can get it fixed - armed with knowledge.
Malcolm
1 - 10 of 10 Posts
