Harmony Ultimate Home - RF Question
1116 Views 2 Replies 2 Participants Last post by  rab-byte
Not knowing a lot about RF functionality and seeing all the "remote" inputs on all my gear, can I come straight out of the home base and into all remote inputs of the gear or daisy chain them? Does this act like a direct RF connection rather than having to use the mini blasters? If so, can I use straight two conductor 1/8" cables? Thanks.
1 - 3 of 3 Posts
bump...
If your gear has an in and out you should be able to cascade the signal.
Yes mono 1/8th should work fine.
This will typically work but some gear (very little) will want some of the IR signal being carried by the control wire to be stripped.
1 - 3 of 3 Posts
