If i'm thinking of the same episode i thought the same thing, wrong subs, outdoor setup, everything was not ideal situations for what they were trying to accomplish.
Now that would be interesting to see! Doesn't it seem like it would have been better to use stuff like the RE XXX18, Mal-X, or some other 18 instead of the 9515's?? If it was meant strictly for ~10hz output?There is no brown note. I agree the test was flawed. The candle test was the same deal. They were using Meyer Sound cabs I believe. Probably tuned to around 35hz.
There was talk from Ivan at Danley Sound Labs that they might have Mythbusters give the Matterhorn a go. That's 40 MTX 9515's (a beastly driver) in a 10hz tapped horn with 20KW or something like that all built into a cargo container for some military simulation or something.
For pure volume there are much better drivers.Now that would be interesting to see! Doesn't it seem like it would have been better to use stuff like the RE XXX18, Mal-X, or some other 18 instead of the 9515's?? If it was meant strictly for ~10hz output?
The Matterhorn is a bass system, not just a collection of drivers mashed together. It's a giant tapped horn with a low knee in the range of 10hz or thereabouts. It is able to produce triple digit sub bass frequencies below 20hz at a distance of over 250 meters outside. It should also be useable up to around 70hz or so.For pure volume there are much better drivers.
The Mal-X and drivers like it are designed for low distortion playback.
Plus horn loaded subs are much louder. Of course they are huge boxes, but hey all in the name of science.
I kinda doubt 108dB at 5hz with those kind of speakers. There was a lot of mechanical and suspension noise going on in the video, so the SPL meter probably picked up on that and amplified the final reading (possibly, but I don't know). But, with 24 Pro Audio speakers, you might be able to hit 100+dB at 5hz, depending on where the boxes are tuned to.
Perhaps, but considering who was running the test rig, and that they appeared to have a spectrum analyzer operating, I'm guessing they could tell if it was 108dB of mechanical noise or not. Which is certainly not to say that 24 Mal-X's wouldn't produce a better result.I kinda doubt 108dB at 5hz with those kind of speakers. There was a lot of mechanical and suspension noise going on in the video, so the SPL meter probably picked up on that and amplified the final reading (possibly, but I don't know).
That's true. And they did the 5hz test sealed, so it will further decrease the output, as opposed to porting ~10hz or so. If they had their boxes ported to 5hz or somewhere around there, I might be able to believe 108dB at said hz. But like the saying goes, there's no replacement for displacement...well somewhat. The new horn designs might be able to best some of the long-stroke, high output 18" drivers.Perhaps, but considering who was running the test rig, and that they appeared to have a spectrum analyzer operating, I'm guessing they could tell if it was 108dB of mechanical noise or not. Which is certainly not to say that 24 Mal-X's wouldn't produce a better result.
About 110db at 10hz for a pair in sealed boxes. 104db for a single.I wonder what a single RE XXX 18" could do on the low frequency stuff? It seems like a very impressive driver.
Speaking of the RE XXX 18, can some one post the WinISD file for it?
