Hi Everyone. First let me say what a great resource this site is. Thanks to everyone who contributes!
Wow this home theater stuff is very overwhelming
I am building a new house and plan to have a theater room/flex family room (15'6" x 15'2"). I am attaching a copy of the blue prints with the layout of the room. Room will be used mainly at night but some use on the weekends during the day. I will do my best to control the light from the windows with curtains but I doubt I will be able to block it all out.
I was hoping to get some advise.....
1. What ceiling mounted projector would you recommend on a $2000 budget? Light from the windows will be an issue.
2. What screen would you recommend based on this setup? I am open to making it myself.
3. I illustrated my speaker placement and in-wall speakers that I am using. What would you change about each?
center - Polk LCiC
front L & R - Polk LC265i
Surrounds L & R - Polk TC65i
Surrounds Rear - Polk TC60i
I know in-walls are not the best choice but this room will also be used for other purposed so the wifey is insisting on them. :innocent:
Thank you in advance for any advice!!!
center - Polk LCiC
