Hi,
I hope the post belong to this sub forum. (AA = FI as i know)
I have Ascendant Audio Havoc 12" , i would like to build a smallest enclosure as i
can to for home theater. (The Power amp deliver 1300W RMS and i have eq parametric also)
On the website the instruction are build enclosure between 0.6-1.2 CF.
but the plans for car...
Whats the smallest enclosure do you recommend? (Vented or Sealed, Tune low as posssible).
lets say for exam only 13" (Internal) sealed Cube.
What do you think???
Thanks for all :)
Welcome! Yellow would be a 13" internal cube with 1300 watts, no subsonic filter needed. Pink is 3 cu.ft. net volume tuned to 21 hz with a slot port 2" x 12" x 44.5" long. The total internal volume of the sub would be about 4 cu.ft. Shown with 1300 watts input and a subsonic filter at 18 hz. A smaller ported design could be had if you're willing to go with Passive Radiators.
Hi Mike,
Thank you for your quickly response. :clap:
Unfortunnely the Pink looks better than the yellow. :sad:
Its no problem to increase the enclosure to 1.2-1.3 max and also afford Dayton Passive radiator (from PartsExpress)
Model SD315-PR.
I just want to build sub better than the Sunfire HRS-12 :hissyfit:
What do you recommend?
Discussion Starter #5 (Edited)
Hi Mike,
May i ask you to send me Havoc 12 WDR file (WinISD).
( i can't send you a private mesage ), my email is zirobit23 gmail com.
Thanks a lot
