1 - 12 of 12 Posts
I am ready to hook up my components and thought about I need to get HDMI cables, and when checking them out seem to not be sure exactly which one to buy. That being said I am hooking up from a Onkyo TS-SR607 to a Sharp Aquos.:huh:
The 28awg 1.3a cables (~$4 for a 6' cable) are suitable for any application as long as you aren't going with extremely long runs. They have enough give to bend and fit into most spots. The 24awg are really thick (~$9 for a 6' cable) and can handle the really long runs - I use these even for my 5' and 6' cables just because they are so cheap, but be warned, they are very stiff and can't always bend or fit where you need them to.
If the runs are over 8' - I would recommend getting a good cable.
That said, don't get swept up in the cable hustle...
I know I was a cable hustler.
Well I only need one six feet long I think, but will measure when I get home from work before buying.
Now that I think about it I need an ethernet cable as well. just remembered I forgot to get a sub RCA connection.
1 - 12 of 12 Posts
