I've trolled these forums for a while and always found an answer :bigsmile:
But I'm stumped on this one, and I can't find it! Here or anywhere on Google :hissyfit:
Here's my receiver make/model: YAMAHA RX-V371
Projector: Optoma PRO360W
I have my XBOX 360 and laptop hooked up via HDMI, and then an HDMI cable going to the projector.
Basically everything works the way I want, except when I'm trying to play games on my laptop. Most of the time a resolution change causes the video display to think it's being disconnected, and then the new resolution sets in, and then windows sees the display (projector) "reconnect". This all happens when I use my YAMAHA AVR.
As you can imagine, all this taking place right as the game is starting messes things up and I can't see the game image!
When I just hook up my projector directly to my laptop (again via HDMI) that doesn't happen. Playing games and changing resolutions is not an issue at all. Since it appears I've narrowed it down to my AVR, now I'm just trying to figure out how to tweak that.
I have no issues using XBOX 360 over HDMI.
I'm ready to hook up a separate audio cable to my receiver (if I must), but that would mean a lot of cable swapping between using my XBOX and PC/laptop. I have a few other options, but going 100% HDMI would be the most convenient at this point.
Has anyone ever experienced this before? Or would know how to fix it?
