1 - 8 of 8 Posts
has anyone had any experience with HDMI splitters.
I am tyring to device how iw nat to split my HDMI signal to two montir devices
projector and a LCD monitor for when projector isn't needed.
does anyone have and brands to suggest?
Also be wary of vendors saying that their device is 1.3 and 1080P compliant. I have some inexpensive HDMI switchers that won't pass 1080P, one other one (Monoprice) that will. It is almost the luck of the draw.
I would give monoprice a try. I see a couple on their site that advertise that they are HDCP compliant and support 1080p with remotes or push button. If for some reason it wont pass 1080p give them a call and Im sure they will send out a new unit. They have very good customer service and the few problems I have had with them have been resolved quickly.
hmmmmm i didn't mean a switch. i ment a splitter. and yes i got one that works quite well.
i wanted to split one hdmi source into multable outputs.
thank you for the help and advice though.
thanks to everyone for bieng so kind and posting inmy thread
1 - 8 of 8 Posts
