I'm looking for a wall outlet extender. I have several power amplifiers in my system that I want to run straight into the wall, but I only have 2 wall outlets (plugs).
I don't need a surge protector, a simple heavy duty power strip without any gimmicks or technology will do.
Anybody know of a good one?
mechman said:
You don't want to use the Juice Bar then? Are you looking for something cheaper? I've never had any problems with the cheap power strips. :dontknow:
Yes, I'd like something inexpensive.
Edit:
I ended up purchasing a Tripp Lite TLM1015NC 10-Outlet Power Strip with Metal Housing. It will handle 1800 watts and does no filtering, perfect for amplifiers, preamps, etc. $47 shipped from Amazon.
We use Tripp-Lites at work to run 6kW worth of computers and storage arrays. They are pretty cheap and built like tanks.
I ended up purchasing the Tripp Lite TLM1015NC. I’m pretty happy with it. It feels like it’ll last forever and it does exactly what I need, ie. doesn’t limit power in any way.
Plain ole user
Good move. I doubt that you will ever find it to be inadequate.
