1 - 7 of 7 Posts
I've been reading many of the very informative posts here and figured I should join in. Am starting a DIY subwoofer project and could use some technical advice.
Hello and welcome to the forum. :wave:
Welcome to the SHACK... Glad you joined.
Hi Don and welcome to HTS!
If you use Facebook or Twitter, click on the supplied links and follow us! It's a great way to find out about new equipment reviews, news, and HTS forum announcements. We also feature lots of other content.
Also, if you have a completed Home Theater or Two-Channel system, get your first five posts out of the way and create a thread about your room! You can create Theater threads (here) and Two-Channel channel threads (here)! If you're designing and building, we have threads (Theater and Two-Channel) where you can feature your builds, too! It's a great way to share photos, ideas, and get feedback!
I just discovered REW and it is a fantastic tool.
I joined because I have a problem. Everything seems to work EXCEPT taking multiple measurements. On the first measurement, I set the levels and I go from 0 hz to 5000 hz with 1M samples which takes 21.8 seconds. It works great and gives me an nice SPL curve.
When I try to do a second measurement, it immediately says 95% complete, and within 1 second, it displays a new graph with no data. Same thing for all subsequent measurements.
If I close the program and start over, I get one good measurement and then it stops working correctly.
I am running Windows 10 on a Lenovo Yoga 3 laptop and I'm using an external USB soundcard (Behringer U-PHORIA UM2).
I'm not sure where to post this on the forum to get a solution.
Rob
Rob
Hi Rob - head over to this section: http://www.hometheatershack.com/forums/rew-forum/ and start a thread. You're sure to get help there!
1 - 7 of 7 Posts
