1 - 9 of 9 Posts
Hi,
I live in India and am planning to build a sub-woofer, the driver and an amp will be picked up in the US by my brother and I plan to build the enclosure here.
I have a budget of $200 for the driver and amp but can go up a little if needed.
I am a complete noob and the reason I am going the DIY route is partly because weight/size limits won't let my brother pick up a complete sub.
The sub will be for music and movies, I plan to hook it up to my PC and would like something that lasts me a while.
Thanks a ton for your help.
Thank you for your suggestions Mike. The Dayton is only rated at 120 volts. I found the Bash Amp which is switchable between 120 to 230 http://oaudio.com/300W_SUBAMP.html.
Would you recommend getting this instead? I can use a step down transformer with the Dayton but they are fickle things and I don't want to fry my amp if they give out.
One last thing, can you recommend a ported design?
1 - 9 of 9 Posts
