Hello guys,
I was curious i really liked the box that dan created and i was wondering if i can replicate this for an Fi Q 18
http://www.hometheatershack.com/forums/exodus-audio/12134-my-sealed-maelstrom-x-build.html
Im planning on using the box mainly for music but also for movies and games occasionally but 98% of the time MUSIC
Thanks, i just want ot know what i gotta do to make it work for an FI Q 18 thanks
Q18
DUAL 1 | DUAL 2
Fs: 24.5 Hz | 23.8 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 5.66 | 5.73
Qes: .64 | .63
Qts: .58 | .57
Mms: 322g | 342g
Cms: 0.13mm/N | 0.13mm/N
Sd: 1210cm^2 | 1210cm^2
Vas: 268 l | 268 l
Spl: 89.7dB 1W/1m | 89.4dB 1W/1m
Bl: 10.4 N/A | 15.1 N/A
Xmax: 27mm
Rms: 1000W
Sealed box: 4-8 cuft
Ported box: 6-10 cuft @ 28Hz
Sub OD: 18.500”
Cut ID: 16.750”
Mounting depth: 10.000”
Displacement: 0.24cuft
Q18
DUAL 1 | DUAL 2
Qms: 5.66 | 5.73
Qes: .64 | .63
Qts: .58 | .57
Mms: 322g | 342g
Vas: 268 l | 268 l
Xmax: 27mm
Rms: 1000W
Sub OD: 18.500”
Cut ID: 16.750”
