Hello,
I am in need of a new sub. Unfortunately, I only have a budget of $300. While doing research on buying a used sub I ran across a DIY build and have chosen to go that rout. This is my first build so please forgive my questions.
My Room:
15'x12' listening area
24'x12' total room size (there is no wall in between my living room and kitchen)
8½' ceilings
sub placement will be restricted to the back corner of listening area
System:
Denon AVR-5700
RBH TK-5 Towers and center
Mirage nanostat surrounds
My listening habits are 50/50
I have purchase an original Tempest 15"($60) to start and was thinking of building a sealed enclosure.
I have been playing with Winisd and believe that a 22"Wx20"Dx18"H box is what I need. Also I have been looking for an amp and found the Foster WF-100K. According to the literature two of these can be bridged for 220W at 8 Ω.
Now for the questions. Is a sealed sub the best way to go for this speaker? If so are my dimensions correct? Are these amps OK or should I look for something else. I have also read up some on the BFD and would like to know if it will help with the response for movies? Any help or suggestions would be appreciated.
My Room:
8½' ceilings
System:
Denon AVR-5700
