G
I don't know anything about home theater stuff, or any audio jargon at all so please explain it to me like I'm a child =)
Anyways, I have a 26D43U Sharp LCD/HDTV, I was going to post a link to it but the forum won't let me since I'm new.
The audio is terrible. So I guess I need to buy speakers or some kind of theater system. Also, I live in an incredibly small house, with a very small living room. I don't need anything fancy. I just want better audio for TV, movies and my Xbox360. I'm going to buy an HDMI cable today for my XBOX360 as suggested by a friend. We have HD cable, and I've basically been swapping out the cables depending on which device I'm using cable or xbox.
Anyway yeah I need better audio, but nothing crazy. I can't really spend more than 500 bucks. If it's possible, I'd prefer a couple of floor speakers and that's it.
Looking at my TV, budget and environment can anybody make some suggestions? Thanks in advance.
-Steve
Hello Steve, Welcome to the Shack!
Do you have a budget in mind? You'll need at least $400 in order to get yourself into something that will last and have decent sound.
G
I can really only spend 400-500 :(
Best Buy has some "packages" or whatever, with speakers, dvd player, etc. for 400-500 but I wasn't sure if that was the way to go or not. Since it's a small house and I'm not really that into this stuff I really just wanted something small/humble, just some better audio for the TV.
This Onkyo system will give you nice sound and will last you a few years compared to most in that price range. If you buy it through the link I gave you you also save some money compared to buying int at any of the stores.
I'll second Tony's suggestion ...:yes:
To get the best theater experience you need to use surrounds speakers, but you can also use front speakers and phantom the rest, but with real surrounds you'll be :yay:.
