1 - 5 of 5 Posts
Am I correct in understanding that a typical laptop soundcard is not sufficient for using REW (I have Lenovo X61 w/SoundMAX Integrated Digital HD Audio).
Can anyone reccomend an inexpensive card to use - this is for amatuer home use to do some setup and testing of a home media room.
Thanks!
Discussion Starter #2
Anyone know whether the Creative Sound Blaster X-fi Surround 5.1 USB card will work with REW?
It does have Line-in. I can't find any confirmmation of whether it is full duplex. It has two RCA outputs for front speakers, 1/8" mini for surrounds, center, and sub (plus toslink).
Thanks for any info.
...a typical laptop soundcard is not sufficient for using REW (I have Lenovo X61 w/SoundMAX Integrated Digital HD Audio).
Well ... if the soundcard has a line and line out (not just the microphone) connection you can use it :yes:
I used this Audigy SoundBlaster 24 :yes:
BTW, Welcome to the forum :wave:
Thanks!
I got one of these on eBay.
http://cgi.ebay.com/USB-5-1-Ch-opti...39:1|66:2|65:12|240:1318&_trksid=p3286.c0.m14
Have used it twice with REW on my old Compaq Presario 2100 laptop running XP home, and it has worked like a charm. Soundcard calibration is -3dB at about 18 Hz and flat well beyond the 3k Hz that my RadioShack SPL meter supports reliably.
1 - 5 of 5 Posts
