1 - 8 of 8 Posts
do I ask help, when I effect the measurement putting the reading to 1/3 octave does it disappear me the measurement because??:dizzy::scratch::explode:
annacamilla.
Not sure I understand the question.
Smoothing is used for full range measurements only. Don't use it for subwoofers.......
the problem is when I put trace adjustement to 1/3 octave and also others it disappears me the effected measurement
annacamilla.
I have no idea what would cause that.
Smoothing is only used on full range measurements.
Below is an unsmoothed main speaker graph. Comb filtering makes the underlying signal trend difficult to see, so smoothing will have to be applied.
Below is the smoothed result.
You are telling me that your response graph disappears?
Discussion Starter #8
everything ok, the problem has been resolved, the cause was the measurement with a staircase from 10 hz to 21000 hz.
putting the staircase from 20 hz to 20000 hz is everything ok.:yay::jump::T
thanks the same for the answers:kiss:
annacamilla.
1 - 8 of 8 Posts
