1 - 5 of 5 Posts
I have a Sanus 15u rack (see pic) that I would like to put in-wall at about 3 feet off the floor. The area behind the wall is unfinished. Any ideas on how best to frame out the opening and elevate it in the unfinished space. I've included a picture of the space with a super imposed image of the rack. I have very basic construction skills.
Thanks.
If the rack is not designed to be mounted in-wall like this one, I would recommend building a platform behind the wall to set it on. That's probably easier than trying to frame all around it and rigging a way to tie it all together.
+1, I would also remove the wheels & replace them with some type of solid block. I imagine it will have to be able to slide forward enough for the door to open. And the molding if you choose to frame that around the opening.
1 - 5 of 5 Posts
