I am looking for some help interpreting these results before I apply any EQ. I am confused by the dip at 70Hz. Crossover is set at 80Hz. Is this normal?
Green is sub only, red is sub and front speakers
Do you have a 30-31 foot dimension in the room? Can you take a measurement a couple feet behind your listening position?
Well, yes I would approximate that my kitchen wall is about that distance. Living room is very open plan unfortunately and HT is still studs :(
Here is the new graph, I moved the UMIK back by approximately 6'
That's better. Can you move your sub (or one of your subs) to the midpoint of that 30-31 foot dimension and re-measure from your listening position?
Discussion Starter #5
OK so I moved the sub (only have one) to the half way point, and measured with the mic at the seating position (not 6' back). I did not adjust the sub distance in the pre/pro or change any crossover settings.
First graph is sub only and comparison between two positions
Second graph is Sub and speakers comparison between two positions
Combined with the speakers, the null seems to be gone. If you're willing to experiment, try sliding the sub in 6-inch increments rearward and forward of the 1/2 way point. A couple measurements in each direction might help fine tune subwoofer placement.
