1 - 2 of 2 Posts
HI!
- Yamaha Hs 7
- Mic: Behringer ecm 8000
- saffire pro 40
- room: 500x500x217 (l x w x h)
- speakers are 80cm away from back wall
- distance between monitores are 106 cm
- monitoring position is 270cm from the right and 230cm from the left wall
- software REW
We measured 5 positions. sweetspot. and all four (up) corners.
Please help me interpret these measurements. (see attached REW measurements)
here is a photo of the room:
"http://imgur.com/lkXiRHt"
here are the measurements:
"https://www.wetransfer.com/downloads/be8975ae411ddf173087b75a76d2d8eb20151121155456/55c8f0ef4af9451b540df67cca90d8c220151121155456/13947a"
sry for mistakes,
greetings
lukas
1 - 2 of 2 Posts
