I’m rebuilding a stereo system after having to pack it away for a decade. My listening tastes have changed over the years and I now find myself wanting a sub to fill in the lowest instruments. I’d like to build it because I’m a woodworker and I can produce something better than what I can afford to buy. The problem is that everything I once knew about speaker design I’ve forgotten. I don’t have a huge interest in relearning it all, so I am looking to you guys to help me pick out and existing design to build. It’ll be paired with Focal Aria 936 speakers, which are supposedly 3dB down at 40Hz but I haven’t had a chance to measure and confirm that. Here’s what I’m thinking about requirements for it right now:
1) Plays down to AT LEAST B0 (30.868Hz). This is required because I listen to a lot of bass music (as in bass guitar, string bass, etc since I used to play one). Playing down to C0 (16.352Hz) would be fantastic, but I have a feeling it’s not reasonable to do. This would be nice because I listen to recordings that include organs with as long as 64’ stops.
2) High SPL NOT REQUIRED! I HATE loud noises. Everyone else’s bass is always too loud. In fact, I stopped going to movies at the theatre because they were too loud. When I have turned up the music really loud just to see what my system would sound like, the loudest I’ve been able to go is about 70dB A-weighted, slow response before I think it’s just too loud and have to turn it back down. Figuring a best-case peak to mean dynamic range of 20dB, that suggests I have no need for the sub to ever go louder than 90dB.
3) Size is not a primary limitation. While I would certainly prefer something closer to the size of an end table than a small car, the truth is I do have more space to work with than I bet most people do.
4) This is for music only. I don’t even own a TV to watch movies on.
5) Probably needs fancy bass management/EQ/DSP. The main preamp for the system does have a subwoofer out but no bass management for the L/R mains. They’ll be run full range with no way to adjust them. So the amp for the sub needs to be smart enough to be set to both EQ the frequency response of the sub and to blend the sub into the mains.
6) Budget isn’t locked in stone. If I could get within spitting distance of $500 for the sub, amp, and supplies to put them together, I’d be very happy. If I have to go a little above that, I can live with it.
So, with all that in mind, what cabinet design, woofer, and amp would you recommend?
