1 - 8 of 8 Posts
I'm looking for a 5 channel amplifier to upgrade to from my AVR. I'm using paradigm studio 20's, and plan on getting an Emotiva pre/pro. My budget it around $500, so I'm mostly looking at used amps. Some possibilitys are: Marantz MM9000, Parasond 5125, Acurus 200FIVE, and Sherwood Newcastle A-965 (7 channel, but I hear its a great amp for the money). Its going to be used for 2 channel music and HT, so it needs to perform well with both.
I suspect any of those you mentioned are going to do you very well with those speakers. My guess is you could hook any one of those up and not notice a drop of difference between them. I would choose the least expensive one... or the best looking one in the price range.
I thought Emotiva had an amp in that price range... or maybe that was one of their discontinued models.
thanks for the advice Sonnie.
Emotiva had an amp called the LPA-1 that was 125x5 plus 50x2 that retailed for $499. they diccontinued it and now they have a UPA-7 thats 125x7 and retails for $649. Still a great price, but a little higher than I wanted to go, especially since its got the 2 extra channels that I'm not going to use. I wish they would come out with a UPA-5 for around $500, but I dont know if they are going to.
Just out of curiosity what receiver are you going to be using as the processor?
Another shack member was kind enough to point out to me that Emotiva LPA-1's can be found used for around $400 plus shipping which seems like a really good deal. Does anyone know if one of those would hold its own against the other amps I mentioned?
I plan on getting a Emotiva UPA-1 when they come out in December, so I wont be using a receiver any more. Sorry if the original post was a little confusing.
Alright, I've got it narrowed down to the Marantz MM9000 for $500 or the Emotiva LPA-1 for $400. I'm leaning towards the emotiva because its cheaper and newer, but the marantz is THX certified, and has 25 watts per chanel. Are either of those features worth the extra $100?
You pay a little extra for the Marantz name and for the THX certification which gives you a certain guarentee of build quality and performance. For $500 I'd say it's a steal! Emotiva gets great reviews online, expecially with regard to low impedence loads. IRRC Secrets did a review of that amp back in the day where they shorted the output terminals with a fork, and it literally sang, but the amp didn't shut down. Personally, I'm a sucker for THX certification (if you can't tell :bigsmile:) and I like the brushed aluminum finish on the Marantz.
Ah, but you get brushed aluminum on the left and right accent pieces of the LPA-1, plus those cool blue LEDs.
I don't know what the warranty is like on Marantz, but if you get the LPA-1, it will probably have a year+ left, fully transferable.
I love mine, it does an outstanding job driving all my Klipsch. All the headroom I need, considering 101dB/1W/1m sensitivity for the mains.
And no, it's not for sale. :R
1 - 8 of 8 Posts
