1 - 2 of 2 Posts
I'd stick with matching LCRs and go with the RF62. This will give you the best panning effects and the best dialog clarity out of the choices you mentioned. I would not go with a horizontal center. The Klipsch is not really a typical MTM design and doesn't suffer as bad in the horizontal dispersion but since you have the AT screen go with a vertical configuration and matching LCR all the way.
Good deal. I think you'll be happy you went that route. If you didn't, I think you'd always be thinking about how nice it would be and you'd end up spending the money twice, once for the lesser speaker then once again for the matching one.
1 - 2 of 2 Posts
