are you sure your amp has the headroom for all that? Sounds like something is running out of steam. (your input or output levels could be to loud and your overloading them but that would likely be a clipping sound not distortion).
I have a 4,000 watt Speakerpower and I'm listening to stuff at -20 db. Yes, I have the headroom. The only time I can unleash the amp is when the MiniDSP is out of the mix. Amplifier output is not even on the radar.are you sure your amp has the headroom for all that? Sounds like something is running out of steam. (your input or output levels could be to loud and your overloading them but that would likely be a clipping sound not distortion).
Ah yes, the old “cut don’t boost” myth. There’s no free lunch - any EQ sucks up headroom. The problem with cuts is that they lower the overall level of the bass, so you end up turning up the amp to compensate. See here and here for details.I'm not boosting much, only one frequency around 65 hz. Everything else is being cut, basically 3 major frequencies, everything else is fine tuning. Everything below 30 hz was already flat, so I'm not boosting that part in the MiniDSP.
What model miniDSP are you using? Some of them have severely limited headroom.The only time I can unleash the amp is when the MiniDSP is out of the mix. Amplifier output is not even on the radar.
It is four Ultimax 18's in sealed boxes but all under the screen. As mentioned before it is a Speakerpower 4,000 watt amp, the SP1-4000. I'd have to dive into the MiniDSP and type out all the filters for an exact list. As previously mentioned I'm only boosting one band significantly at all, I think around 65 hz, about 6 db. Everything else was just pulling down expected peaks from room mode issues.Not much information to go on, not knowing what specific speakers or amp you have, how you have things connected, the amps configured, no details on the specific EQ filters in use, etc.
I could live with "some" lower headroom but the action I took by both pulling down peaks and pulling down the output gain by 10 db does not seem to be a step in the right direction at all. It is so far off what I would consider to be even remotely correct that I even decided to make a post here.Ah yes, the old “cut don’t boost” myth. There’s no free lunch - any EQ sucks up headroom.
Yes but if you boost it aren't you potentially clipping the MiniDSP? I don't know what else would cause the bad distortion that I experienced. Also, my amp already has DSP programming in it to get the subs flat, otherwise sealed subs have a rolloff that you have to correct for. So realistically, the low end is already boosted to counteract this rolloff. If I see that area being flat like it should be, then I see a big boost where a known and expected peak from a room mode should be, what would be the correct action to take, boost the known to be correct low end even more, or kill the incorrect peak from the room mode issue?The problem with cuts is that they lower the overall level of the bass, so you end up turning up the amp to compensate.
Believe it or not, supposedly Dennis Erskine shoots for this same 1.5 db window, BEFORE he applies any DSP. I cannot confirm this.Aside from that, your graph – well, it’s just too pretty.
Either it’s smoothed (unsmoothed graphs are best for sub response) or you used like a million EQ filters, which is not a good way to go.
The common 2x4.What model miniDSP are you using? Some of them have severely limited headroom.
Minor filters are of no value and indeed can cause problems. I’d suggest reviewing my Minimal EQ article.I'd have to dive into the MiniDSP and type out all the filters for an exact list.
It's probably 10 filters but most are very minor.
There’s your choke point. If it’s the unbalanced version, IIR its maximum input headroom is only .9Vrms. Speakerpower specs the SP1-4000’s input sensitivity as 4 dBV, which translates to 1.6 Vrms. What’s probably happening is that at the point you get enough signal from the receiver to get the subs singing, the mini is clipping. And as you’ve experienced, clipping in the digital realm is especially nasty.The common 2x4.What model miniDSP are you using? Some of them have severely limited headroom.
That seems like it would be an issue with any amp, not just Speakerpower. Audessey on my Marantz actually set the subs to be -12 db. If a MiniDSP can't handle a very common receiver's output at -20 db with the subs at -12 db, then what good is it? Is there a more appropriate one?There’s your choke point. If it’s the unbalanced version, IIR its maximum input headroom is only .9Vrms. Speakerpower specs the SP1-4000’s input sensitivity as 4 dBV, which translates to 1.6 Vrms. What’s probably happening is that at the point you get enough signal from the receiver to get the subs singing, the mini is clipping. And as you’ve experienced, clipping in the digital realm is especially nasty.
A receiver’s level indicators have no meaning in absolute voltage output (Vrms). The figures are referenced only to the maximum output of the unit itself: A -20 dB setting on any receiver basically means “we’re at 20 dB below our maximum output.”Audessey on my Marantz actually set the subs to be -12 db. If a MiniDSP can't handle a very common receiver's output at -20 db with the subs at -12 db, then what good is it?
MiniDSP offers a balanced version of the 2x4 that has 2 volts headroom (it can be used unbalanced). Or, get a professional-grade device like the Yamaha YDP2006.Is there a more appropriate one?
You could get a signal booster and insert it after the mini, which would allow you to boost the signal coming into the amp and run its gains lower.Yeah I just got off the phone with Seaton, he acted like the balanced version would do what I want. Also thought the normal version could be made to work though.
If that’s happening with a subwoofer, either Speakerpower's S/N noise figures (95 dB) are bogus, or the miniDSP has is generating a lot of noise on its outputs.This would require boosting the gain on my Speakerpower though, and when I do that I'm picking up way more noise than I believe is acceptable.
Sounds like he’s read my stuff - hee hee!He also more or less said knock it off with the smoothing of every little anomaly.![]()
Before this, what I've experienced with sub noise is that you either have a high pitched hiss, which I've experienced with Crown XLS and Behringer iNukes, or you have a ground loop. The noise I'm getting is in between these tones, have no idea how to describe it but it's more of a low midrange thing.If that’s happening with a subwoofer, either Speakerpower's S/N noise figures (95 dB) are bogus, or the miniDSP has is generating a lot of noise on its outputs.
Strange, I can't recall setting up such a thing and have no idea why I would.Looks like there are crossover filters active in the miniDSP for the output(s) you are using.
