Hi skank. I run 7.3, and my personal preference is for direct radiators. Ymmv. I would also mount them so they are roughly 6' off the floor,or about 3' above seated ear height, in basically the arrangement you've shown.
Nice rendering.
by reading your first post Im assuming you already have the speaker purchased so if that is the case I would have the bipoles on the side walls and the direct behind you.
Bipole speakers generate an extended soundfield by reflecting the sound off adjacent walls. They might not work exactly as intended when the walls (like yours) aren't vertical.
FWIW, the new Dolby Atmos sound decoders seem to work best with monopole speakers, not bipole, dipole or tripole speakers. Atmos soundtracks are recorded so their sounds are supposed to come from the vicinity of the speakers, not spread out by being reflected off walls and ceiling. (Except when one uses "Dolby Atmos Enabled" speakers. They are intentionally designed to reflect sound off the ceiling, simulating speakers actually located on the ceiling.) You might want to take this into consideration, even if you aren't planning to upgrade to Atmos in the near future.
Hello all,
New to the forum and hoping for some direction regarding of my issue. I recently moved my home theater surround sound from one area to another in the family room and mounted the TV. Here's the old equipment/setup: Pioneer VSX-917 (2 HDMI, 1 optical TV/Sat, 1 digital out optical, and...
Hi everybody,
Thank you for having me.
I just purchased a new Samsung home theater HT-J5530, and I managed to install it successfully, I think.
I tested by watching a blue ray DVD, and the sound is great, however when I was trying to watch Netflix or YouTube on it, the sound comes muffled and I...
Hi Everyone
I am looking for some advice regarding components placement,
the most popular spot is in the front of the room,
I have been considering placing them at the back of the room, behind the second row couch.
Room is 3.6mts wide 4.9mts long and 2.4 high.
my components are 2 multi...
Hi Everyone,
I have nearly finished construction of a home theater room,
It's small, measures 4.8 mtrs x 3.6 mtrs x 2.4 mtrs,
I need to get some advise, before I start running speaker wires through the wall,
the usual place would be in front, under the TV,
I have also, considered, place...
Hi all-
I have a Samsung 49' Q6 TV and a Samsung N550 sound bar with sub, what is the best way to connect them? I tried optical but got distortion on loud pieces, now I'm going HDMI into the bar HDMI out into the audio return channel and still getting some distortion when a movie gets loud...
