1 - 3 of 3 Posts
iv got a question an i hope you can help
im planin to build some bookshelf speakers that have 2 8in woofers an a planar tweeter
in a two way config using the
Dayton Audio 700-LPF-8 Low Pass an Dayton Audio 700-HPF-8 High Pass
but my problem is i cant see how to do that , i know it should be simple but iv always had difficulty doing some thing without a visual specs
that why i like wiring diagrams
so could someone show me a visual diagram on how to connect them up in this way or direct me to some software that can
my design concept is to consist of
two Dayton Audio RS225P-4A 8" Reference Paper Woofer 4 Ohm
Product Specifications
Nominal Diameter8"Power Handling (RMS)80 Watts
Power Handling (max)120 WattsImpedance4 ohms
Frequency Response35 to 5,500 HzSensitivity92.9 dB 2.83V/1m
Voice Coil Diameter1.52"
the woofers to be wired to 8 ohms as series
________________________________________________
paired with a Bohlender Graebener Neo8S Planar Transducer
Tweeter TypePlanarImpedance8 ohms
Power Handling (RMS)50 WattsFrequency Response300 to 20,000 Hz
Sensitivity93 dB 1W/1m
plus 1
Dayton Audio RSS265-PR 10" Aluminum Cone Passive Radiator
________________________________________________________
my box spec are
net internal volume of 2.582cubic feet
system q = 0.525
two 8in woofers ,one 10" Passive Radiator an 1 Planar Transducer
dims are 11.25in wide by 22.75in high by 5.5in deep
with the bottom ,top,left,right an back sides covered with .25 in of Acoustic Sound Damping Foam
an the tweeter mounted in a horizontal orientation with a wave guide straight through the box
below the two woofers with the rad centered between the two from via the rear side
just match the input and output +ve and -ve of your two Dayton crossovers to the attached illustration, replacing woofer with your two 4 Ohm woofers in series
I have had many attempts to post this, hope it works this time :frown:
1 - 3 of 3 Posts
