1 - 5 of 5 Posts
I want to use the FireBox and ECM-8000.
I also have a Radio Shack 33-4050 SPL meter.
I have the Following questions:
1. Can I use 2 outputs of the FireBox for L and R to the preamp of my stereo system?
Or do I have to use only one output and use a splitter ?
2. Should I use the "MAIN output" or "line output" of the FireBox ?
3. In "Soundcard preference", should I select Java or ASIO ?
Thank you guys in advance.
> Really, there's no right or wrong way to route output signals ,as long as they get to where you want them to end up .
> But (fwiw ) ,I would use ASIO because it allows one to wire up outputs 1 & 2 ( of your soundcard ) to the stereo inputs on the pre-amp & then decide ( from within REW's preference window ) which pre-amp input to select to route the signal to ( ie; it's only one choice at a time from REW ) .
> In case you are not aware, one measures a single speaker per measurement ( mains type , to avoid cancellations from comb-filtering to skew the test results ) . Multiple Subs can be measured together .
:sn:
Thank you for the reply.
I did not know that. Even when you measure for room acoustic treatment ?
Yeah, I see that you can only select one output at a time in REW.
In this case, I will connect both "Main Output" of FireBOx to the preamp's L and R inputs; then select L or R from REW.
I will choose ASIO.
> You should probably ask that question in this sites dedicated Acoustics Forum
> I always measure using a single stimulus ( speaker ) to check the fundamental acoustics of a room .
> Ask within that forum & ( hopefully ) get the views of its resident acoustician , " When is it appropriate to use one or more stimulus ?" .
:sn:
1 - 5 of 5 Posts
