I am getting frustrated with Harmony remote not being able to send commands the way my actual Integra remote can. Seems like if you hold down a button it won't keep sending infrared command, causing the button for volume to take to long to raise volume level. Also with up,down,side to side buttons for scrolling through menus. I spoke to Logitech Harmony tech support they said program in the raw mode.That is not helping? Anybody else have this problem? The remote works but way to slow. Any help much appreciated. Thanks
