Model Code: SP52Q7HRX/AAG
Type No: EX52Q7
June 2004
Hello and greetings from Germany!
I recently purchased a used DLP. After some issues with the convergence I was realyy happy with it. It is Us Spec, so I'm writing in this Forum.
One morning it did not switch on. The (single) LED is flashing until I turn it of. I DO hear the "click" as supposingly the power switches on, but there is no picture.
My guess: The bulb went out.
My problem: I opened the rear cover and see a lot. But no bulb.....
What I tried: Google -no result
search Forums - no result
Samsung - no answer
Download the manual - worked, but no info in there, not even on the color code.
So I hope that someone can tell me something about my DLP. I could not even find technical specs on the unit online. I am not new to the internet or to doing research but this one makes pull out my hair!
To just call in a TV tech is pretty much useless since DLPs are somewhat rare over here.
Well thank you for any help, comments or insults that may come ;-)
Ray
Type No: EX52Q7
June 2004
Samsung - no answer
Ray
