1 - 3 of 3 Posts
I just finshed setting up my hometheater/computer/desk in my bedroom and am having trouble with the optical output. My tv only has 1 optical output and no analogue outputs for audio. I am using a denon receiver that has an optical input and no optical outputs. Also, digital signals are not decoded to analogue through the analogue outputs on the receiver (for cdr/tape). My headphone set (sennheiser rs175) also uses optical or analogue inputs. However since the tv has no analogue outputs, I must use the optical signal.
I tried two different optical splitters, one passive and one active. Neither worked
This is the passive I used: https://www.ebay.ca/itm/Dual-Port-T...hash=item1eda6fd794:m:m1h_qDEYafQbqd0leJnxzlQ
Here is the active: https://www.amazon.ca/Portta-N3AP13...d=1526667030&sr=8-2&keywords=optical+splitter
Any suggestion how I could resolve this?
yes unfortunately I think I will have to replace the receiver. Maybe some of these newer receivers with HDMI inputs will covert to analogue. Meanwhile I am using the headphone out to my headphone base station but its not as clear as a direct optical input.
I suppose the optical splitters dont actually work?
1 - 3 of 3 Posts
