1 - 4 of 4 Posts
Hello friends, I am a rookie and WinISD browser.
I want to build a subwoofer for my home theater.
Right now, I have two speakers, Troesl Gravesen project, acapella, composed loudspeakers Seas, woffer w22ex001 + w18ex001 + tweter t25c001, with a sound that to my taste is very good. blu ray oppo95 + denon 4311 and pending Jungson JA88d/09 amplificardor.
I'm looking to build a sub with ultimax Dayton 15 "500w Bash amp.
You see the dayton ultimax15 and amplifier Bash 500???
It will be enough space for approx 60mt2 = (200 ft2)??
Can anyone suggest an alternative???
We thank you for your attention and sorry for my bad English, I speak Spanish.
Best regards.
Are you going to buy a pair of them or just one?
Is this for HT or music?
I'd rather listen to music 70/30% music / home theater.
I have budget for one subwoofer, in a couple of months maybe install the second sub​​, I would like to achieve a good result with a single sub ..
Using WinISD, I see the Ultimax in 25Hz Dayton has a fall
very large compared to TC15. "also noticed a significant difference in RT.
latency at 15 Hz
This influences the positive outcome of the two drivers, or the difference is minimal and imperseptible??????
Not as posting here, a photo of the calculation obtained by WinISD.
The TC Sounds woofers are very good but it depends on your budget. If you can afford the TC subwoofer then buy that but if you are more money limited then buy cheaper and use more if needed.
1 - 4 of 4 Posts
