So it's been several years since I've built anything and equally as long since my last post. Work just keeps me too busy... however, I just recently moved and have a small window of opportunity to build a sub for my current set-up before the Air Force throws me back into a non-stop work schedule.
I sat down to my laptop and started doing some research yesterday but 24 hours later my wheels are still spinning. Here is my situation...
I have a Crown XTi 2000 amp to push whatever I build.
I would prefer 2 separate subs but one is fine as well.
Size is not too much of a factor but I'd like to keep it 350ltrs or below if possible.
My room is quite large... 35' wide x 30' deep
I am looking at a passive radiator build with the TC Sounds 15Q1 and their 18" passive radiator but I'm also open to other options. I'd really like to get a good range out of this thing so I tend to lean more toward ported than sealed.
Unfortunately my laptop that had bassbox pro on it for my last build broke many years ago. When I got my new laptop that was the last thing on my mind. So when I went looking for it... you guessed it... it was gone. I'm not buying it again as the military moves me constantly and I rarely build so Im looking for not just advice but as much help as I can get with the specs from anyone who has the time and ability to help me out.
And no... I cant get WinISD to do anything for me. I've ran the numbers 5 times, quadruple checked them and ran it again... nothing seems to be working. It has never worked for me so I always ran with bassbox... It's been SO long that I feel like a Noob again.
This was my last build...
http://www.hometheatershack.com/forums/diy-speakers/12087-finally-finished-revelator-build.html
Thanks again for any help anyone can provide!
