1 - 5 of 5 Posts
I'm trying to set up REW to measure my sub's response but I can't move beyond the soundcard calibration (using a Creative Soundblaster X-FI Surround 5.1 External USB Sound Card with Windows Vista). I have the soundcard connected via USB and the RT LINE OUT connected to LINE IN. There are no other connections to my laptop or to the soundcard.
When I run the test, the measurement looks like the picture under #5 "If the measurement looks like this:" in the REW help file "Calibrating the Soundcard" (which help file says "it is probably due to a feedback loop from the Line In to the output. This can happen if the soundcard has some feature for record monitoring - for example, on the Soundblaster Live 24-bit External there is a "Monitor" feature for the Line In that must be turned off to get correct results, on some other Creative soundcards (e.g. Audigy 2 ZS) there is a Record Advanced Controls setting for "Record without monitoring" that must be selected."). I would attach picture but this is my first post...
I cannot find any setting in the Creative soundcard controls to enable/disable the "monitoring" feature. Any idea if I'm missing something, or if this soundcard is even suitable for REW?
Any help is greatly appreciated!
That's what the post padding thread is used for.
Click the red + by the Line In/Mic In symbol in the Source panel and ensure Monitor is not checked in the Advanced Controls dialog this pops up.
I noticed that there is a very detailed description of REW use with that particular card at the end of the Help feature within REW iteself....give it a read if you have not already. A lot of card settings seem to lurk in non-obvious places. I however do not have FHE with that card.
BK
To check in Vista if your soundcard is in monitor, check the Playback Devices screen (right click speaker icon in Windows System Tray) under properties / levels. Be sure that the line-in is disabled in Playback for your selected soundcard (as shown in the example attached jpg), and line-in is enabled in Recording Devices.
Discussion Starter #5
Thanks. That did the trick. Sound card calibration looks good. I appreciate the speedy response!
1 - 5 of 5 Posts
