I am able to move the red and blue andjustment lines, but as you can see the green is curved upward on the sides. If I am able to make adjustments does this mean that it is not the IC and possibly something else?first step is to change the IC if you cannot adjust it.
:duh:Am I just making matters worse or did I maybe help myself a little. In a side note after it turns off the light does not flash. Error code is 12 normal operationWith the TV on thought I would push on the IC heat sink gently to see if maybe the solder joints are loose and presto TV goes off. TV now will turn on and instantly off.
