Hi im trying to design my first sonotube sub using the mach 5 ixl-15.2.2 i come up with 6 ^ft tuned to 18hz. the subs ts
T/S Parameters
Fs = 23.4Hz
Re = 3.7 Ohms
Qes = 0.41
Qms = 5.94
Qts = 0.39
Mms = 343.8 g
Rms = 8.51 kg/s
Cms = 0.135mm/N
VAS = 94.4 litres
Sd = 706.9 cm2
Xmax = 22 mm
i will be powering it with a dayton rack 1000 watt amplifier that has a preset hpf at 18hz can someone tell me how close i've come with my modeling? and what is the minimal diameter tube i can use i have it a 18" right now but would like to be more definite before purchase. Thank you
:hail:
You're right on the money. Make sure you measure the internal diameter of the 18 inch tube as not all of them are the same. You'll need a 6" tube for a port that is 35 " long to keep the port air speed acceptable.
Here's all the dimensions you'll need to know. :T
Text Line Screenshot Font Parallel
