I am the proud new owner of a Mach 5 ixl 15. Mainly because it modeled so well in a smallish box in WinISD. The sweet spot for me is a 3.95 ft^3 internal volume tuned to 21.98 Hz. I like the look of a little taller box than a perfect cube, but hey if you are willing to help me out I don't care!:help:
Preferrable demensions are 38 tall 18 deep and 18 wide. But 24 high by 22.5 wide and 22.5 deep are Ok as well. If you have another idea please post it!:bigsmile:
The biggest problem I am having is figuring out the slot port.
Here are the spec's for the driver:
T/S Parameters
Fs = 23.4Hz
Re = 3.7 Ohms
Qes = 0.41
Qms = 5.94
Qts = 0.39
Mms = 343.8 g
Rms = 8.51 kg/s
Cms = 0.135mm/N
VAS = 94.4 litres
Sd = 706.9 cm2
Xmax = 22 mm
I will be wiring this at 4 Ohms and running with an EP2500. (Not bridged...for now:devil
T/S Parameters
Fs = 23.4Hz
Re = 3.7 Ohms
Qes = 0.41
Qms = 5.94
Qts = 0.39
Mms = 343.8 g
Rms = 8.51 kg/s
Cms = 0.135mm/N
VAS = 94.4 litres
Sd = 706.9 cm2
Xmax = 22 mm
