G
Guest
·Well this is really to help out my Dad with an issue he's having with his setup. After getting tired of looking at the rats nest of wires on a stand alone entertainment center, he moved the components to a book shelf off to one side of the room away from the TV. A Cat 5 wire was run from the components thru the ceiling and down the wall to an HDMI wall plate, from the plate an HDMI cable to the TV. The speakers are also conntected thru a wall plate. The set up works, the problem is when the furnace turns on or a nearby light switch is turned on, the audio and video go out but return to normal usually within 10 seconds. There is no loss of power to the TV or components. The installers who did the work suggested it was a loss of voltage when the furnace kicks in, they recommended an APC battery back up, but so far that really hasn't helped.(I would think if it was a loss of voltage the TV would also go out) I know the installers are at wits end and I know my Dad is fed up with it, because every fifteen or twenty minutes the system goes out.
The components are a Pioneer Elite A/V receiver. Not Sure of Model. Direct TV Box, Sony 60" XBR LCD and the wall plate i think is an MIS(could be wrong on that).
Looking for some ideas on whats causing this and how to fix it. Thanks for taking a look.
