Hello, I am new to the forum and am in the process of putting together a HT system. I have already built a 5.1 system consisting of the Tritrix MTM Transmission Line(main) + Tritrix MTM Vented Center + Tritrix MT Surrounds. These speakers do pretty well into the mid to low 40 hz range. My current receiver is a Onkyo SR-607. Now I am in the process of deciding on a sub. Something that will play the ultra-low frequency's. My room size is about 20x16 and is opened into a kitchen area (counting the opened kitchen area the dimensions are around 20x35). Size is not a real factor (except for I don't want something that is going to weigh 500 pounds). I think that I have decided on Bob's 15" Subduction model sub along with the Reckhorn B-1 as my highpass. I am leaning towards the Behringer EP1500 but am opened to suggestions. I really can only afford 1 sub (my driver cost limit is around $300) at the present and this sub seems to be the best "bang for the buck". I have started plotting some things in WinISD and here is what I have come up with. A am relatively new to this hobby so I am sure there is something that I might be missing out. Also, as far as bracing goes. How much volume will the port and bracing account for? Also, what thickness mdf would you recommend? Thanks in advance for your help.
