1 - 20 of 69 Posts
D
Guest
Hi all! New to the forum and looking for some help!
I have a Samsung DLP hlr5067wax/xaa. It is 2.5 years old. In the last few months it has started having this intermittent problem where it gets these green lines acroos screen. Live pictures is still in backround and sound is good. Happens on all inputs. I do not notice any abnormal sounds coming from TV. Occsionally it will start working perfect and do so for a few weeks, only to turn it on again and have it go back to this issue for a few days.
Lamp appears to be fine. Also, color/pictures, ect on all menu's is fine. Anyone have any ideas on what this is? I am hopiing it is a common problem. Please help if you can. Thanks for your time.
Re: Help with my Samsung DLP hlr5067wax/xaa. Screen Shot attatched
I have redirected your thread in the Video Displays forum so that you may get more help. From what you say and pics, it seems your TV need to go for some service checks.
Are you running your video signal directly from the source to the TV, or through a receiver?
It looks like no receiver is in the loop.
D
Guest
Discussion Starter #5
Cable is plugged directly to TV however I do have tv hooked up to a sony reviever.
OK, while I'm not a Samsung DLP repair expert, I spent quite some time looking into this particular problem. The first thing I would try is cleaning and resetting it. Reset the TV by unplugging it from the wall, and leave it unplugged while cleaning. When you're done, plug it back in and fire it up. That procedure seems to take care of the problem for some people.
I don't have access to a Samsung DLP, so I don't know the cleaning procedure for it. I'm sure it can be googled or someone here can tell you how. If you really just want to try something quick, then just reset it without cleaning (which also seems to have worked for some people).
There are apparently prolific problems with the $700 "digital board" (sounds awfully generic to me, but that seems to be the name) for this set, which also may be the problem. If it turns out that the reset/clean doesn't fix things, and no one else has any better ideas, then I would call Samsung for service. Apparently, if you tell them that you know about the frequent problems with this model's "digital board", you may get some relief from Samsung...even out-of-warranty. The key appears to be nicely (but firmly) escalating the call to their 3rd level of customer service (Executive service). They have offered help ranging from providing the part for free, part and labor for free, or offering a very good credit towards a new model. Of course, some got no relief. In this scenario, you'll still need to have it diagnosed by an Authorized service center and provide the diagnosis as "proof" that the digital board is the problem...and then insist that Samsung help you out given the circumstances that this is a well-known "issue".
Hopefully, some others (more knowledgeable than me) will chime in with additional input...but I wanted to get you started with the basic things you can do that may help. Good luck, and keep us posted!
D
Guest
Discussion Starter #7
thanks! I will research it and try cleaning it. The reset does seem to work however I need to leave it unplugged for an extended period of time. Example: Last night I tried unplugging it and plugging it back in several time and was not able to get it to work. I left it unplugged all night, plugged it in this morning an it worked fine! Once it works it usually stays working for a few weeks.
A
Guest
Discussion Starter #8
I have the exact same DLP, with the exact same problem.
Have you tried the HDMI or Component inputs? When I try those the problem is different, it will go into a "freeze frame" with the sound still running, and after a few minutes it will reset itself and work for a little longer (2-10 min) and then do it again. I initially got it to work by unplugging it, and I also read somewhere else that you can do a reset by holding the power button down while unplugging it. Not sure if this is doing anything additional that just unplugging it, but the first time I tried that it worked for about a week, but now its back to the acting up.
One odd thing is that the PC (VGA) input seems to work all the time, so I have considered getting a component to VGA converter and hooking it up that way.
Any luck with getting help from Samsung? If I could get the part I would be happy, I have had it apart a few times and changing the boards doesn't look any harder than a motherboard swap on a computer.
J
Guest
Discussion Starter #9
I am having the same problem. PC RGB connection works fine, everything else is a green tint destorted picture. The sound is fine though. Also when I am viewing the distorted picture, the remote doesn't work very well.
Did you figure out what the problem was?
John
In looking at the troubleshooting manual, none of their examples match what you have shown. They do mention either the IC’s 403 or 601 or the soldering to them (for 2 of their examples picture issues). Below is one example of how they mention the fix for one of their examples. All of their examples, if not fixed be the solder, go straight to a replacement of the DMD board.
Error in the LVDS Receiver (IC 601) or the soldering
The H sync signals are not transferred to DDP1011.
→ Replace the DMD board.
Plain ole user
My guess would be the DMD.
A
Guest
Discussion Starter #12
I think the DMD board is pretty expensive, and not worth it to fix a 2 year old TV. So I haven't done anything with the TV since it broke.
I've thought about getting a converter to convert from Component video to VGA and just using the VGA port that seems functional. Will I loose any resolution doing this? There are cheap converters like one made by startech (around $50 to$80) and more expensive ones (couple hundred dollars), the difference seems to be something having to do with whether or not the "synch on green" is acceptable to the VGA input. Any idea if one of these converters will work and will I be giving up picture quality by doing this as a workaround until I can buy a new TV?
I am also worried that if I buy a converter box, the VGA port will stop working the day it arrives. Is there a reason the VGA port works? Do all the other inputs require processing that is done by the DMD board prior to going to the DLP for display, and the VGA port does not require that, or is it just dumb luck that the VGA port works?
Thanks for the help.
Plain ole user
I must have missed that the VGA works fine. If that is the case, your problem is not the DMD.
Has anyone found out the exact solution to the problem "dmacii" is having? I am having the same exact problem and want to know if it is worth fixing the tv. I purchased my tv in Dec of 2005.
Was the problem the DMD Board? Did you fix the TV? If so, did Samsung cover any part of the cost to repair? Just wondering if it is possible to ge them to repair so I don't have to buy a new TV.
Plain ole user
I don't know the resolution of the problem, but I would be very surprised if Samsung would do anything on a set nearly four years old. IME, they are one of the least likely to accomodate a customer on a castastrophic repair, especially at that age. Mitsubishi, maybe, with some leverage from a good dealer, but not Samsung. It never hurts to ask, but don't expect much.
D
Guest
Discussion Starter #17
I still have not found the resolution to my TV issue. I guess you could say I kind of gave up for awhile. The unplugging it to reset it seemed to work ok for a while. Usually if I leave it unplugged overnight, then plug it in the next day it will work for a few hours. I also found unplugging it and plugging it back in repeatedly will get it to work sometimes, after say the 6th or 7th time in a row.
Another thing I have found is that when my screen does what it does in the pictures I posted earlier, the PIP will show a perfect picture still. So sometimes I will put PIP and tv on same channel and watch the little screen. It just does not make sense to me while PIP is perfect and regular screen is jacked!
I started cleaning TV tonight finally becasue my wife got sick of the issue and put TV in garage! I will let you all know if I finally figure anything out. I hear TV prices are coming way down at the end of the month... I have been holding off hoping to get myself a 50" Plasma for 700-800 bucks.
W
Guest
Discussion Starter #18
I have the same exact issues with my HL-R5067WAX/XAA that I purchased 12/05. However, the digital/HD display works most of the time before it starts to cut out intermittently. My research tell's me that an analog PCB board replacement will fix this (part #BP94-02049E). I just don't know if the digital PCB is also going out or whether it is a result of the analog board issues.
I've talked to Samsung's ECS dept. with no resolution (they seem to be OK with the fact that their T.V.'s last 2.5 yrs.). After all the money pitfalls and wasted time, I may be better off learning from this and start shopping for a non-samsung product.
Plain ole user
Please specify what YOUR symptoms are when you post. There may be subtle differences that lead to different conclusion. It is also confusing to others to refer to other's symptoms in previous posts.
R
Guest
Discussion Starter #20
Hi There,
I have the exact same problem ... Green bars on tuner video while VGA works perfectly fine. Resetting doesn't seem to work all the time for me, sometime it does and sometime it doesn't (I let it sit for a day and try again - then it works).
Did anyone have luck changing the DMD board and fixing the problem ?
Thx
1 - 20 of 69 Posts
