Hardly. It can be anything from less than 6dB to typically between 10 and 15dB for many generators.Pink noise has a crest factor of 6dB by definition.
REW's pink noise generator will produce a low crest factor pink noise, it's built-in custom filters will band limit at 40Hz and 5kHz (or anything). You can play it live or save to a wav file.As for limiting bandwidth, Equalizer APO from sourceforge might do the trick.
What do you need it forI need a pink noise signal with a crest factor of 6 dB, filtered at 12 dB/octave below 40 Hz and above 5 k how do I set it up!!
