Hi all. This is my first post and I'll try to keep it simple.
I have a room that is 12' by 21'. My fronts (PSB B25's) are 8' apart and toed in. They are 3' from back wall, 1' from side wall and 11' from prime seating position. The center (PSB C40) is centered between fronts above TV and is slightly tilted down toward prime seating position.
Due to the room's seating I use rear speakers (PSB B15's) that are back wall mounted above the seats 8' from prime seating position and 7' apart. These are tilted down,toed in, and 2' from side walls. The sub (Velodyne DSP-12) sits slightly behind front right speaker and is 2' from either wall.
Other notes: drop ceiling with ceiling tile used and all crossovers set to 80Hz.
The room sounds ok but I think it could sound better. Does anyone have any suggestions?
Thanks
Thanks
