J
j12ramse
·Guest
I am putting together a home theater and need some detailed advice. Recommendations on equipment, or budget allotment would be really appreciated. If this works out, may even be a good sticky for others building a small theater.
Current setup: The room is 13' x 16', two rows of seats and doors in the back. There are no windows and the ceiling is painted black and the walls dark blue. Prewired for 7.1, and 4 other rooms prewired for stereo sound, including outdoor patio. Have a PS3, and Dish Turbo HD. (Note: Know that 5.1 would be fine, but want to try 7.1)
Estimated Budget: $15,000
Questions:
1. What size screen should I buy? Gain? (viewing distance 1st row ~ 8', 2nd ~ 13', leaning large, but want enjoyable viewing)
2. Recommendation on projector? (High quality visual is important, HDTV, Blue Ray, etc.)
3. THX Receiver recommendations? (Like Onkyo products, will need 7.1 and output to connecting block I think?)4. Connection block, and using independence-matching volume controls in the other rooms? (Does that sound right? Tips?)
5. CD Mega Changer?
6. Do I need a Video Scaler, Amplifier, and/or AC Power Conditioner?
7. Suggestions on Theater & other room & Patio speakers? (Tower vs. bookshelf, watts, type or budget)
8. Subwoofer suggestions? (7.1 vs 7.2, size, location, budget)
9. System set up vs. self install, & system calibration?
10. Floating Riser needed?
11. Suggestions on a good rack for equipment.
Lot's of questions, but the input would be most appreciated. I've spent a lot of time researching, but seems the more I learn the more I get confused on this.
Thanks,
Jon
Questions:
5. CD Mega Changer?
Thanks,
Jon
